JDM113
- September 15, 2010
- Minneapolis
Some time ago, my 2002 Explorer decided to quit directing heat into the ventilation airways. I also began hearing what sounds like a door repeatedly opening, and closing time and time again from the right-of-center area under the dash. When I turn the fan to high, that noise stopped and the heat would start coming out. More recently, another noise began - this time from the left underside of the dash. Once again, the sound of a clicking, door-opening and door-closing noise. When I turn the temperature knob to left (cold) the noise stops. When I turn it to the right (warm) it begins again immediately. Probably a simple fix for someone who knows Explorer ventilation systems. Is this some kind of weak/bad actuator, or vacuum leak, bad switch? Also, where's the best place to get a ventilation system diagrams / illustrations? Thanks in advance for the words of advice!!!
I wanted it to be as easy as possible so I took out a bunch of stuff and cut the dash. The method I used required the whole console to be removed along with the brace and the lower heater duct and cutting the dash. Like you said, we get it done & save a ton of cash. You better get off the computer and hook up that power point. :biggthump
