mikeonabike
- December 17, 2019
- Kansas City
- 2006 xlt 2wd 4.0
Ok, first and foremost i have found many forums talking about similar issues and fixes for them but they are all for different engines/different year models/ different generations. all of which dont seem to apply to my engine/model setup. if you know of a forum that covers these problems please direct me to them, i have scrolled through about 20 pages on this group and cant find the exact problem/solution to my problem so here goes, hopefully the explorer guru has a helpful solution for me
my explorer has a little over 200,000 miles on it and has lived a fairly easy life with a decent effort in maintenance but nothing over the top in regards to care, about 10,000 miles ago a idle problem started to rear its ugly head every now and again where if it got any where near 500RPM it would just drop RPM and die. the car drives fine as long as it stays above 1000 RPM. so when going down the road there is no power loss, no stuttering no issue at all. highway driving is completely fine and actually runs really well when going down the road. it will run and drive fine for a few days with no issue then one day it will bounce its idle from around 300RPM to 600RPM but as soon as you take off it works fine, it accelerates fine it shifts fine, no issue to be seen till you take your foot of the gas and let the idle drop then it will just die becasue the RPM dropped too low. when it starts to do this RPM bounce it will eventually lead it just killing itself entirely when it tries to idle. now i have seen people talk about the fuel pump could be bad but other than the p0193 code i dont seem to find any other characteristic of its performance to believe that is the problem. I have seen others post about how it could be a vacuum leak but every post people where people discuss that is for the previous engine before 2005. the vacuum line they seem to point out i cant seem to find on this engine. I have also seen people talk about how the throttle body needs to be cleaned or replaced but again this seems to be a solution for the previous engine, not the SOHC 4.0 I am fairly mechanically inclined and just replace the valve cover gaskets and intake gaskets so i am fairly capable for a drive way mechanic. I am really hoping that someone on here has the answer for me so i can slap myself and say "DUH!" and drive this thing without worrying about it dying. below are some more details of other problems that could relate to what is going on.
1. car pops a P0193 code occasionally, i know this is a FPS problem and from everything i have read it doesnt affect drivability of the car at all but i figure that needs to be on the list.
2. a P0506 code will pop when the problem kicks in but goes away ass soon as the car starts working fine again.
3 no power loss at all and as long as it stays above 1000RPM you would never know there is a problem
4. the problem comes and goes. it can drive fine for a week and then just screw up for no reason
5 weather doesnt seem to affect it neither does drive time or engine temp, at least i have yet to find a commonality when the issue pops up.
6 the engine has a throttle body spacer on it and a K&N air filter but these problems were happening befoere those were installed.
if you have any question please ask them i will be checking this post fairly regularly because i have a long drive coming up for the holidays and i would love to get this solved before the trip. thank you everyone for reading this long post and any help you guys and gals can offer.
