james t said:
What is the rig doing Robb? Symptoms?
Basically, it sounds like a Model-A when running.
There is a constant miss throughout rpm range. The timing point where it runs the best, is also the timing point where it won't start (that may just be weak starter, or rusted "thick wire" connections). Actually getting the engine to the point where idle speed and timing is correct, to spec, runs like trash and has no pick-up.
The biggest problem I see with it's setup is that seems to be during Ford's "transitional" period to modern engine management. They added more crap to that carb than they should have ever done (ISC, TPS, etc). It actually does have a "computer" in it, and I think that it isn't doing anything. Under no circumstance can I get the timing to advince. The ISC valve plunger won't even come out far enough to meet the throttle linkage at idle. And I can disconnected various vacuum/electrical elements with no change in engine performance.
It has all the normal new stuff; plugs, wires, cap, rotor, filter, plus a N.O.S. carb. Everything right now is pointing towards a breakdown in the primitive management system. I got a feeling I could grab a computer from the boneyard for near nothing, so that is my next plan of attack.
