1992 Eddie Bauer
- December 13, 2009
- Walla Walla, Washington
- 92 Eddie Bauer
I have a 94 Explorer that I just put a used tranny in. I have been driving it around town a little bit for the past couple months or so and everything has been fine. Shifts real good, no problems....until tonight.
I was driving across town getting ready to jump on the highway and came to a stoplight. Upon attempting to take off the vehicle didn't want to move and the engine revved a little (not bad, maybe 2000 rpm) and then slowly started to move. Once we got across the intersection I looked in the rear view mirror and saw a little bit of smoke. I immediately turned around and headed for home. Came to another stop on the way home and when trying to take off the engine revved to 4000 rpm before it started to move (it was acting like it was either low on fluid or it was slipping, but since I saw smoke earlier, I assumed it was getting low on fluid since it seemed to be draining as I was driving; hence the smoke). Just not sure where it's leaking from.
So I got it home and jumped out and looked under the vehicle to see if I could locate where the leak was coming from (engine was still running) and couldn't see any leaks. I then shut it off and looked under it again and that's when I saw it starting to pour out the vent/overflow tube, which runs on top of the tranny at the rear up towards the top of the bell housing and then down the drivers side of the bell housing. So I watched it pour out probably about a 1/2 to 1 quart of fluid (guessing the amount) before it stopped draining.
It has a new radiator and the lines aren't plugged. Prior to installing it I installed a new filter and pan gasket along with a new front pump seal. So I know there shouldn't be any leaks from those two areas since it has new a new gasket & seal.
Question.....what would be causing it to drain out the vent/overflow tube? Any other possible problems I'm overlooking? I appreciate any feedback.
