Hey Guys
-'95 Bronco 302 (EEC-IV with distibutor)
To start with, we (my and I) are just assuming a lean condition by the fact that the exhaust is years old and very clean at the tip, actually a bit white. Only have had the truck about a month or so, and has had noticably less power than a '91 302 we had a few years back.
Only code thrown was a TPS code, it has been replaced. Along with: plugs (showing lean condition also), wires, cap and rotor, fuel filter, O2 sensor, and cleaned MAS. Fuel pressure is well within specs. Timing has been set. K&N has been added. Had the pressure drop accross the CAT checked by trusted muffler guy and found to be fine.
With these fixes, performance has improved.......but still not great yet. Simply not as quick as the '91 was with the same gearing. My dad's main concern is that he wants to start towing his 21' SeaRay with it soon, and is scared of it running lean while towing.
What else should we look into? Nothing else seems to be bad enough to throw any codes.
Thanks for any suggestions!!
