CD-6 shipping mode | Ford Explorer Forums
CD-6 shipping mode
crazymikey
Ontario
2002 Mazda B4000 4x4 4.0L
hey guys,
I just received a CD-6 radio from a 2004 Ranger Edge to put into my 2002 Mazda B4000.
I had it sent from the states and the seller put it into shipping mode for me. On top of the radio tells you instructions how to put it INTO shipping mode,but not how to get it out of it. I assume that it would be the same sequence of events.
However, I have tried that, which is to have the key in ACC and simultaneously press 2 and 5. Almost any combination of buttons I press makes the cd changer make noise, but when pressing load or eject it says SLOTS FULL even though there are no discs in it.
On a side note, I cannot set the clock or adjust the sound settings, even while following the instructions from the owner's manual.
This radio had been in his truck since new,removed,sent to me and installed in my truck and I can't figure out what to do with it to get the cd changer working.
Any ideas? I've searched all over the net for the past 2 days looking for info and I can't find anything other than the possibility that the mechanisms inside have come apart and jammed the cd trays.
did it have a means of holding the the trays during shipping? Like some Bracket, Bolt, Cardboard. If you didnt remove anything from the top, and the radio is allowed to tip upside down, the trays probably fell off the guide post and are now jammed. You can send it in to be fixed or if your handy, take it apart and look for something obvious.
It's supposed to come out of shipping mode when you give it power and want to insert a CD. I'd say there's something definitely wrong with it.
Greeeaaaat. I took it out of the truck this morning, so I will have a look at it later and take it apart. Didn't cost me anything to get this unit, I just did a straight trade for it, so if it is messed,I'm only out like $15 for shipping.
