InkWax
- October 2, 2003
- Pitman NJ
- '98 XLT
Ok, easy one first. Can I hook my PIAA 1100s' Switched Power (+) to one of the fog light lines or is there a better place?
Next, Back in January my CEL light came on. Couple weeks ago I got around to having the mechanic check it out for me. When he pulled the code it was a bad O2 sensor (not suprising since they have been in for about 140k).. So, he replaces it for me and sends me on my way.
Later that night the CEL comes on again. So a few days later I take it back and have them read the code.....Too Lean / Too Rich..... Now he did say when he pulled the old O2 sensor that it was white. I talked to a friend of mine and he said that meant the engine is running too lean.
Lately, I have had troubles with hesitation and downright sluggishness in acceleration. Based on talking with my friend and reading about CEL's related to O2 sensors on the boards here, I have a feeling that my fuel system is well part of the issue.... (Fuel filter has 166k on it....and the 98 V8 XLT has 272k miles on it.....)
So, my question is.....
Do, I have them run a fuel pressure test, replace my fuel filter, and then have them retest it to see if that was the problem? Or should I just have them replace the fuel filter and then test fuel pressure? Or is there another route I should take that I am missing? (I dont have the exact codes or I would post them)
No matter what I am getting a new fuel filter....I want them to do the fuel pressure test...
Should I (after they are done "fixing" my filter etc...) toss a can of fuel injector cleaner or something like that in to help it out?
Any suggestions would be appreciated.....Thanks
InkWax
InkWax
