- March 16, 2013
- Woodstock, GA
- 04 Ford Explorer 4.6l
My 4.0 is out. Putting it all back together. Oil pan and timing cover are in place.
Installed a Melling M328 pump and was going to try and prime the pump manually by rotating the crank.
Start rotating the crank (without balancer on it) and the rockers are moving and pistons are 'try' to compress (plugs are out.)
Spun it quite a few times with a ratchet and was able to do it with some speed.
So I get out the 1/2" drill to give it a little more power. Only problem now, is the rockers stopped moving with the rotation.
When I look through the timing cover, where the balancer shaft goes, I can see that the crank gear isn't moving at all.
There wasn't any resistance during any of this.
So what did a "break" and what do I need to do now?
Getting ready to pop the timing cover off. Let me know if I don't need to.
