skoal_mint
- September 19, 2005
- Geraldton ontario
- 97 explorer sport 4.0
Is it possible to change my transfer case output bearing? Today i was junt the truck and decided to check my driveshaft, and when i gave it a shake (up and down) i noticed alot of play...then i see it was the bearing in the transfer case..So is it a job that i can do without spliting the case or removing it?
Also, what kind of fluid can i put in the t-case? i have 80-90 fluid for my diffs, would that work?
Becasue the bearing probly casued the seal to go bad and i noticed a dark stain forom the fluid always leaking out
