Explorer_PL
- November 16, 2007
- Rockland County, NY
- 06EB V8
Few weeks ago, I had to jump my 06 v8 twice in the morning when it got really cold. I had an Interstate good quality battery that was installed 20 months earlier. I went back to the shop where I bought it and they warrantied it and just gave me a new one. I thought I was good to go, but the next day the car hesitated and eventually started but something was not right. Since I drive every day it starts every morning but there is that hesitation and it cranks for few seconds lately.
I went back to the shop to do load test, but instead they disconnected the positive cable and put a light probe between the + cable and + post and the probe lit. They closed the doors, shut down the car and expected that the light would go off or dim down but it stayed lit. They concluded that I have a short somewhere and it's draining the battery. The voltage whit engine running was slightly over 14v so they concluded that the alternator is OK. Since they were closing for the day, I took the car home to see if I can trace the short.
With the light probe in line and lit, I removed every fuse and relay one by one under the hood and under the dash, but the light never went off, and the current read slightly under 1A . Since I have another explorer 07 v6 i decided to do the same on the 07 and it read slightly under 2A with the key off and doors closed. That makes me think that the draw is normal and I do not have a short.
I started both cars on and the 07 v6 that has no problems starting read 14.5 v on the battery, while the "problem" v8 read 13.69 v with the engine running, and sometimes 13.1
This is still the original alternator that came with the car in August 2005, 257k miles ago.
Is the mid 13v readings too low and that may be my problem ?
