Cheap extended brake lines | Ford Explorer Forums
94_Xploder
1980 Toyota
Gathering the rest of the parts for my lift and need some extended brake lines. Read on TRS you can use BH 38622 and 38623 for the front brake lines and they are around 26in long instead of using a set of aftermarket lines. Well on my old ranger I had the skyjacker line fail on me twice so id rather something I can pick up locally if something were to go wrong again. I can seem to find those BH 38622/38623's but came across these:
http://www.autozone.com/autozone/pa...Z8knp9?itemIdentifier=124520_166223_5913_6717
From everything I have read, these are the same thing and should work. Anyone running these?
Did you ever end up trying those brake lines out?
