qumanchew
- January 28, 2012
- Kutztown, PA
- 03 sporttrac Turbo Diesel
k, a bit of real wisdom here now,,
if you put on taller tires and regear for them, you don't need to recalibrate the speedo,,
if i run 33 inch tires and my speedometer is only off by like 1/2 a mph and that is with 4:10 gears,
it had 3:73 stock,
reflashing the computer may settle the issue that way, but it is incorrect to do it like that,, the truck will lose power cause it is trying to hard to lug the big tires ,
I don't think you're following what I'm trying to accomplish. I didn't re-gear to compensate for the larger tires. If that was the case I would have geared it lower (numerically higher). I put on taller tires and geared it up (numericaly lower) to get my cruising rpm's down so the diesel engine is in it's sweet spot when cruising at highway speeds.
