Niels
- March 19, 2009
- Benson, MN
- 1999 XLT w/ 4.0 SOHC
Hi all. I have a '99 SOHC XLT all stock. Last week the temp gauge dropped down to the "C" while driving. There was plenty of heat, but the radiator cap was cool to the touch. The wife brought it to the mechanic because of this and the Check Engine light was on.
The mechanic put the code reader on but no codes were logged, according to him. He revved the engine a couple of times and then the CEL went out. Well, now it is back on and stays on. Good heat, all the gauges are working correctly and nothing odd has been noted with the performance of the engine. Everything seems normal.
Given the fact that the CEL is on I tried to find some place open today to pull the code, should there be one. Nothing open on Saturday, of course. The code reader that I borrowed does not have the EEC-V connector. Is is possible to pull codes using the ignition switch like on the Chrysler vehicles or is a code reader the only way?
Also, and I know this borders on a vague/stupid question
, what could cause the temp gauge to drop and the CEL to come on? I did look at the temp sensor connection and all of the rest (air cleaner, oil pressure, various vacuum lines, etc.) but I couldn't find anything out of place or obviously wrong. Thanks for any insight or thoughts.
