Check Engine light on... | Ford Explorer Forums
snaipa
Kailua, Hawaii
1991 Eddie Bauer
I am wondering what could be the problem with my '91 E.B. explorer... I used to have a problem with it reving extremely high in park but that is fixed... i still have a ridiculous amount of mpg...on average my truck should run about 270 miles per full tank...i am now running out of gas at 150-170... it's terrible! i also have no torque, or kick when i push the accelerator. what can i do? oh yeah, i just bought a chilton's repair manual... does anyone recommend learning everything on my own? I don't know anyone who can help me with my explorer, and i have barely any knowledge.
Sounds maybe like a failed FPR. Does it smell like it's running rich? You should test the fuel pressure and compare it to the Ford specs.
Your Chilton book should also give you a procedure to retrieve the codes from your truck since your CEL is on. Or Wal-Mart sells a code reader for about $35 that will do the same thing. Finding out your code will help you greatly in fixing this problem.
Robb
edit: 1974 posts............I was born in 1974 :confused:
How much do you think it would cost to fix my problem if i just took it to a ford dealership?
