Pollarican
- October 10, 2006
- Wall Township, New Jersey
- 1991 EB 4dr
Hey guys,
Ordering some of the last few parts I need for my full 4.0 Overhaul - Last three things I really need are:
- Main Bearings
- Connecting Rod Bearings
- Piston Rings
After inspection and measuring, the crank journals and cylinder bores are all still within OE spec - the engine had 135,000 on it. Going to be ordering OE sized Main and Connecting Rod Bearings, as well as OE bore Piston Rings. Block will get a hone before hand.
Some Questions:
First question, as far as fittament, It seems all "Standard" fit connecting rod bearings are .002" oversize - Is this common practice?
Second, Is there any real difference between a "Moly" material vs. a standard steel for piston rings? Should I be looking towards Summit for a premium quality supplier for piston Rings?
Lastly, Is Sealed Power the brand I should go with? It seems DNJ offers a these bearings at a cheaper cost - but I am skeptical.
These parts are all going in a fully overhauled 1991 4.0, with SI valves, 410 cam, new 93tm heads, smithbros pushrods, new lifters/springs etc. The truck will be a daily driver seeing some somewhat regular, mostly hillclimbing/trailriding offroad use. The goal of the build is a good all around off/on road motor that can pull a decent weight trailer if need be, yet have bulletproof reliability and better mpg than stock.
- Main Bearings
- Piston Rings
Some Questions:
