Clearing and reading ABS codes on a 1996 Aerostar. | Ford Explorer Forums
jamesle
sacramento
1996 ford aerostar
now that ive made repairs, how do i clear the light on the dash manually?
i had only the 500 code(speed sensor) which is on the diff rear axle is there one on the tranny also or how do i clear the brake and rear abs lights without the code reader?i replaced the brake shoes , bleed the lines changed diff fluid tested the ohms on the sensor within range.
:aerostar:
