Yobida
- March 7, 2011
- 1993 Explorer Sport
Hi, everyone. I'm the owner of a '93 Explorer Sport that I've had for two years, driven a lot. Recently, I was unable to start it and had to have it towed home. I had several people tell me what it must be (different things, of course), so I've replaced the battery, relay, solenoid and starter and it still does exactly the same thing.
The easiest way to explain it is that the relay clicks, but doesn't turn over. I know, it's the battery is what everyone says first. Heard that one. It's not the battery because my horn also doesn't work... completely. There is a sound when I hit the horn, but it's a low toot, barely audible, so clearly there is something amiss in my electrical system. It does the same thing no matter what battery I use, so, I hope you'll forgive me repeating that it's not the battery. There are so many wires and cables that I don't know where to begin trying to isolate the problem.
I did disconnect the two wires from the starter on one end, and the positive terminal of the battery and relay harness at the other end, and tested for continuity, which I found, so I know that neither of those two wires is open. Also, that wouldn't have anything to do with the horn not getting enough power, so that was a wasted diagnostic, I think.
I would have searched for something, if I knew where to begin searching.
TIA for helpful souls.
PS: the title is true. I just recently began trying to work on this thing myself out of financial necessity. I'm learning, but I know next to nothing about automobiles. So far, my experience has been replacing the starter, starter solenoid, starter relay, fan clutch, and battery.
