cluster problem | Ford Explorer Forums
cluster problem
MotorCityFats13
Flatrock MI
2007 Explorer XLT 4.0L
2007 Explorer XLT 4wd 4.0 SOHC... last night driving home from work my IP started to flicker and dim and then went completely out. Only the high beam and blinker lights function and mecanical gauges, all other functions as far as I can tell still work but the rest of the cluster does not illuminate. I checked the fuses and all were good is there any relays or other modules that I should check before looking in to sending out the cluster for repair... DTC codes are B1915, U1900, U0154 and U021..... most of them if not all are network communication errors between the cluster and the PCM.... seems like something inside the cluster might have shorted out or died. I have not been able to see if this affects the ABS or RSC functions or airbags making driving unsafe.
update.. abs, traction control and 4wd all work
