hairdo
- August 17, 2008
- zanesville,ohio
- 95 xlt /2004 limited
hello , have snap -on obd 1 tool and cel check eng light , so had 2 codes 1 soft 335 egr pressure sensor fault - i replaced - now it's 111 -ok still have check engine light and is a 214 cam position sensor fault - i erase and it comes back with every restart .. so 95 v 6 245 cid push rod i removed cam position sensor at rear of manifold by removing air plenium but wow is it hard to get at or what.. have it in my hand .. question how can i test this unit the other type is 35$$ mine is a intrigal type app. 325 $$$. is it relly bad ??? my best option thx .. jack is there a ohm's test ????
