Similar problem
I have a 94 4x4 xlt 4.0l .So this is whats going on while driving one min its normal great on fuel then once in a while it suddenly speeds up and then boggs down as I watch the fuel gage drop. Checked for codes (as the cel doesnt come on??!!) I get 543 koeo as well as in the memory if I clear codes it doesnt come up until it starts acting up again what I've done so far check wires from firewall to pcm and reset they seem fine also checked relay and swaped it. Fuel pump primes at start. This has been going on for last 4 months. Could the pump be acting up like this for this long and maybe needs to be replaced. ( I always thought when pumps go they go now!) Any input would be great My husband is ready to push it off nearest cliff!!
Thanks Deb
I have the same vehicle, similar issues. My experience with vehicle repair is limited, but I like to take on a challenge! Let me start with my codes, explain my symptoms, and then what I have done so far to resolve this.
My KOEO codes are 543 and 332. The codes came up on my scan tool in the order 543, 332, 543. I don't know why the 543 is in there twice, but perhaps that was where things started to go wrong.
This vehicle was purchased from my dad who owned it for several years and took really good care of it. I have owned it for 2 months now. My dad mentioned an engine 'surging' problem during warm weather, and I noticed it also after I bought it from him. It was only a slight surge, so not a real problem to me - I can't say if it was severe or not as it still ran OK. Our mechanic was unable to find out the cause of the 'surging' so it has been unresolved. I also have noticed extremely poor gas mileage - around 11MPG in 2-wheel drive Then, last week the 'check engine light' came on after driving for a half mile or so. Maybe this was because the engine started to warm up or something around that time.
So, I bought a scan tool (Equus 3140) that has OBD1 connection adaptor for the '94 Ford to get my codes. The instructions said to warm up the car and then run the diagnostic. This was my first experience using a scan tool, and because I was following the computer instructions and not reading the manual first, I failed to connect something to the adaptor - not the trapezoid cluster of 4 or 5 pins, but the single pin connection off to the side of the trapezoid - I think that is called the EEC-IV wire. I started the car and ran the tests to get the codes. After reading something else online, I think I should have done the tests with the engine off, and tried to resolve that before moving on. But I didn't really know any better at the time, so I did the KOER test before fixing my problems. During this test it seemed to run a little funny for about a minute - idle was a little off, but then it slowly started to sputter and die. I disconnected the tester and it's cable from the car, but now I am unable to start the car again. It will make some engine noise like it wants to start, but it just won't kick in and make any combustion happen. There are no little pops or almost engine starts, it just spins and wont get going.
What I have done to fix this is that I tried to figure out what the solution for code 332 was. From looking on the internet for answers, I have found several posts stating the 'Differential Pressure Feedback (DPFE) Sensor and Hoses' could be the cause. So, I got this part from a parts store and replaced it today. When I did this I noticed that one of the hoses was badly cracked. The dealership was closed today, so I am not able to get the hoses from them. For testing purposes I used some electrical tape as a patch on the hose. I will be replacing the hoses with Ford parts because my parts store says they are specific hoses for high temperatures and that normal hose would not work - they also did not have any substitutions for these hoses. Anyways, I think that will fix my surging issue when I can get the vehicle started again. It was probably a cracked hose, and possibly a faulty DPFE sensor.
Now, I am struggling to get the car started! After replacing that sensor and patching the hose, I cleared the codes on the computer and tried to start it and then I tested for codes again. Again the car would not start. The same 543 code is coming up again, which has brought me to this forum.
I do have a Haynes repair manual, and the internet as a guide, and this forum response is somewhat helpful. I might just have to play with the wires and connections some more. If I really have to play with the wires and test everywhere that is OK, but I might just have to tow it to a mechanic to look it over. Is is possible that my scan tool caused the problem, or maybe I blew a fuse? Maybe my problem is an easy fix since it was scanning the vehicle when running, that may have caused some obvious damage somehow?
Thanks for anyone that can help!
