Coil Spacer ? | Ford Explorer Forums
Coil Spacer ?
Badali05
Highlands Ranch, Colorado
91 Eddie Bauer
I'm putting on the coil spacers, but I dont know how to get the retaining clip things off that are inside the coil itself. Can some help me out please.
what retaining clips are you talkin about? the part at the top of the tower or the nut at the bottom of the coil?
The nut at the bottom of the coil, it is taking me forever to just use a wrench to turn it. Is there any easier way?
Nope that's pretty much the only way to get them off. Just a bunch of exentions and a bunch of wrenching...after I got them off mine my arms felt like they were going to fall off :)
Good Luck!
CP :D
use an extension and some wobbles and get at it through the top of the coil tower..... also make sure you spray the crap out of it with a penetrating oil.... a blow torch also makes bolts loosen up quite well without melting them.....
