coil spacers and shackles | Ford Explorer Forums
snooper0069
iowa,louisiana
1993 explorer sport
i want to put coil spacers and shackes on my 93 X . could someone give me some advise as to what size spacers and what size shackles to get. also how many spacers do i put on each spring.
One set of F150 Coil spacers and one set of War153 shackles.
do you mean aftermarket coil spring spacers for f150s will fit on our explorers?
F2TZ5A307A Ford Coil Spring spacer $13.99 ea
F2TZ5A307B Ford Coil Spring spacer $13.99 ea
From torrie@fordpartsnetwork.com
(Or you can order them through your local dealer)
And you can order the shackles by calling 4wheelparts, it isnt listed on their website but they carry them. I just did this lift and it got me just shy of 2" in the front and exactly 2" in the back.
Remember you will need an alignment and probably new camber bushings aftewards (I got quoted around $140 for that)
-Matt
is that 140 for the new camber bushings and installation? if so could i do that job myself and save some money?
Yeah,
Thats what Im planning to do, the bushings should be around $20 - $30 and from what I have heard they arn't that hard to install, see my post in suspension and lift kits called Camber Bushings....
After that an alignment should cost around $50 or so.
-Matt
