coil spacers | Ford Explorer Forums
coil spacers
jDan
sacramento, ca
92 Exploder
I have a 92 explorer and was interested in installing some coil spacers up front along with some new springs that I purchased from Performance products. They are 1" longer than stock and I am looking for an extra 1/2 -1" with a spacer. I do realize that I will need the adjustment cams and an allignment afterwards. I was curious if anyone knows the dimensions for the spacer so that I can have a local welding shop make me a pair. I have looked at Superlifts Homepage but no dimensions are given for their spacers. Tips on the install would also be appreciated.
Thanks,
Dan
See the previous post " Coil Spring Spacers" on 10/21. Hope it helps. Sea ya
jDan, i just made and installed a set on my 93, i made them 3"o/d by 1.25"i/d by 1/2" thick. the i/d is thght to the spring stud but it will fit- just be patient. good luck!
SCOTTC
93XLT 4X4 4DR.
Do you guys know if these same spacers will fit 93-97 Rangers? As I'm sure you know Rangers sit uneven and I'd like to get my 94 slightly leveled out. I can get the spacers made easily but I don't know if it exactly the same on my truck as your Explorers. Thanks much guys!
Adam
1994 Ford Ranger 4.0L 4x4 5spd
Mods: K&N, 63mm T-body, Superchip
[This message has been edited by 4x4Ranger (edited 11-08-1999).]
