jwrezz said:
What do TOD, and TCS stand for? How would we (95-96) get 2wd low from this, if it is only an electrical modification as opposed to the vacuum disconnect mod? Thanx,
There's no need to mess with the Center-Axle Disconnect when you can simply force the transfer case to de-couple the driveshafts.
TOD is Torque On Demand. That's the one on the right side of the stereo opening.
The transfer case shift relay (TCS) is on the opposite corner down behind the GEM. (the TCS relay is hidden by the light in this pic... that's the GEM on the left)
Both relays have a brown wire that runs to the upper left hand corner of the opening where they are spliced in with a third brown wire that runs to the Transfer Case Clutch Coil.
The clutch coil is what locks the front and rear driveshafts together, and as far as I can tell, it works in a similar way the AC compressor clutch does.
You must cut the wire downstream of the splice.
If you cut the wire between the splice and the TOD relay, when you shift into 4low, the TCS relay will engage the clutch coil and lock the front and rear driveshafts together. By placing the switch in that particular wire, when you deactivate it, it forces the transfer case to disengage the front driveshaft, even though the planetary reduction gears are engaged for low range, hence you get the 2wd low range.
Now, in the case of the '95-96, in order to use the full-time 4wd, the selector switch must be set to 4 auto to engage the center-axle disconnect (followed by the switch used to force the full time transfer case engagement). If you wire it up the way I suggested above with the SPDT on-off-on switch, you can force the driveshafts to engage, but you will still need to rely on the GEM to engage the Center-axle disconnect. I suppose you could always replace the front axle with a later one to eliminate the CAD, but that could be more work than it's worth. Another option might be to adapt the 4x4posi-lock unit from the F-150 to fit the Explorer, but again, it may not be worth the effort.
On a completely unrelated note, I'd love to get my hands on an un-used transfer case to tear it apart and see what makes her tick. Anyone got one laying around they don't want?
-Joe
