Coolant level problem | Ford Explorer Forums
1996B4000
Heathsville VA
1996 B4000 LE
1996 B4000; 5-speed stick; 196,000 miles.
About six months ago I found a pinhole leak in the radiator. Local shop changed the radiator.
I check fluids and tire pressure weekly. EVERY time I check to coolant level, the reservoir is empty and the coolant in the radiator is barely visible. I just keep adding fluid to both.
The truck is parked in a garage with cement floor; no evidence of leaks -- no oil, coolant, or fluid of any kind on the floor. Temp gauge stays slightly below mid-point.
What is going on? What can I do about it?
Thanks,
Your average old guy
Most likely out the exhaust pipe. How many miles driven between empty reservoirs?
I had the same mystery with my 94 B4000, disappearing fluid with no visible leak. I was having to add about a half gallon every couple days.
Last month I tried K Seal in the radiator and have not had to add fluid since!
