My gfs explorer
- December 19, 2021
- Cincinnati
- 04 explorer 4.0 flexfuel
Two issues, possibly related, possibly not.
First. For years my girlfriends explorer has had a coolant temp gauge issue. See picture. Any input on what all it would entail to hopefully repair this cluster would be very appreciated. I have about average soldering skills.
Second. I noticed after installing a new water pump, that the radiator fan is seemingly on constantly on. No, the ac isn't on. But with all HVAC off and a cold engine, the fan came on immediately and never turned off for over half an hour.
A third thing, and I almost look at this one as good news everything else considered, I didn't change the thermostat when I did the water pump and I believe it is stuck open because during that half hour of letting it warm up, it would seem to lose heat during a long idle but would come back quickly when you pressed the gas. I'll have her hopefully verify that when she takes it to work tomorrow, but does that right? Also, upper hose never got hot or firm. Even though heat was blowing out of the vents.
For what it may be worth, 04 Explorer, 4.0, 4wd, flex fuel.
Thanks in advance for any input or advice.
