MattPersman
- February 27, 2003
- Westfield, IN
- 91 4x4 Sport
Hi I am a new owner of a 91 X Sport 4x4 blah blah. anyways doing some routine maintenance on the thing, one thing I noticed was the coolant gauge is always way low. Now it is cold here in Indiana like it got to 25 maybe today, but was 4 degrees when I went to work this morning, but anyways even this weekend when it was 37 the temp gauge didn't move a whole lot. I did a search and it seems to replace t-stat, coolant temp sensor, etc. I did the T-stat, added new coolant. No help there, didn't seem like the old one was bad when I took it out but who cares its under $10.
So I figure, I will go to the coolant temp sensor next. went to autozone and got one for $15. I put it in. its the one on the right top of the T-stat area with the 2 prong electrical plug, I popped that in. Let my truck idle for like 10 mins and took it for a quick 5 min drive top speed of like 55 mph and still reads low. Doing the search I noticed in a few threads about 2 sensors? I am guessing I replaced the one that gives info to the ECC (the computer as I think its called in Ford terms, was a GM man before this). Is there truely another one that sends the reading to the gauge? If so whats it called and what can I ask for at the autoparts store. I have access to most major midwest parts stores in driving range.
Anyways really the only thing I did not change was the radiator cap. I think I may swing by and get one after work tomorrow cause who knows maybe its bad? Never had one go out on all the vehicles I have owned so who knows. It says replace or test on top of the cap. Also I did not flush the radiator but it looked decent in there. Could the cap be my culprit, or maybe the "other" sensor?
I can only guess MPG is effected by the thing thinking and actually running this cool. I rather have it this way than overheating I suppose.
Thanks
Thanks
