shadow460
- January 5, 2016
- Oklahoma City
- 1998 Ford Expedition
Well I went outside to pack the 98 Explorer for a trip to east Texas and what do I find but a big puddle of green goo and a busted side tank seal on the radiator. No problem, right? Especially since I have an Expedition sitting right there I could load and take. My wife is staying here a day longer, so she drove her truck and I guess if worse comes to worse I can ride back with her.
I chose the hard path. I swapped out the radiator, loaded the Explorer up, and took off with my stuff, extra gas, oil, and coolant. When I refilled the system I filled the overflow bottle close to the top expecting it to bleed air on its own and suck in some coolant. Then my dumb self forgot that the heater core is shut off when max AC is selected. To be honest, it was probably shut off through the whole radiator changeout.
The level in the overflow bottle is dropping but it's still well above the cold fill line. I did turn the heater on max for about ten minutes at a rest stop. During the whole 350 mile trip I watched the temp gauge like a hawk and it just camped out right where it usually does. (I'd tell you if the temp fluctuated but I left my fancy code scanner at home).
There is no evidence of further leaks on the system, no white smoke, no smell of coolant, no puddles other than condensate, nothing.
I've got 100 miles to drive tomorrow and then 350 miles back home, and I think I'll make it with no problems, the truck is showing no signs of distress, but set my mind at ease, would ya?
I think it's just air trapped in the system...
