Crankshaft position sensor | Ford Explorer Forums
mhanglow
new york, ny
1195 ford explorer
Where is this sensor located on 1995 explorer xlt 4.0 ohv 6 cylinder
back of the motor, near the firewall, and not fun to reach
Wouldn't that be the Camshaft position sensor? I figured the crank sensor was the one attached to the front of the engine pointed at my crankshaft pulley. It has the metal ring with the notches like an ABS sensor. Or am I thinking of a different sensor?
S-
whoops! sorry about that, yea, the CAM sensor is in the back
No worries. And you're right. That cam sensor is in a bear of a spot. With the M5OD out of ours? I can actually get to that sensor. I'm tempted to replace it while I can see it...
S-
Thank you. How about the pinout for the pcm ?
Auto - Online Repair Info
http://search.ebscohost.com/
Login ID: chattech
Login PW: quarter
Select: Auto Repair Reference Center
Fill in: Find Your Vehicle
Follow prompts down to Wiring Diagrams.
Good luck
