Cruise control still not working 2000 EXP EB | Ford Explorer Forums
JAMES209
fort worth,tx
2000 explorer 5.0L E B
It worked while I had the jumper wire in the disengage plug on my way to Autozone and to home. But after I installed the switch, it won't work either way. I have continuity at the switch, but no power to the switch. Fuse checked out also. My frustration level is awful high. Any thoughts?
Found problem :blown 2 amp inline fuse on recall harness . Now working .
i am having problems with my cc too, but i checked the harness and it said that if the fuse is blown it needs a different kit fitting. i think if it blows something is up. might be a risk
Did you replace the cc disengage switch located on the master cylinder?
no but i have tried the bridge method with a paper clip to see if it faulty still no cc
ant ideas
cheers onetime
tested the cc switch on master cylinder working fine i think did it with meter. closed when brake pedel not pressed open when it was.
that's good testing ... but you need to do a bit more... like check for voltage coming in the switch AND leaving.
just got it working the harness was loose on the servo just pushed it back in, however i pushed the on/off button on the stearing wheel to hard and broken it off, and the bulbs have gone out but it still works. so now need to replace that or repair. but i now have cruise control for the first time taking the kids out a long drive tomorrow.
thanks for all the advice
onetime
