yyc_tbird_sc
- December 15, 2005
- Calgary, Alberta
- '92
Hey guys, I found an explorer today in pick-n-pull that had 3.73 gears and a traction loc carrier. Obviously the rear is easy to disassemble, but I'm having a problem removing the front carrier. I've got the drivers and pass sides axles taken out of the knuckles, the drive shaft disconnected, and all the bolts out of the front of the axle. The damn carrier still won't budge, I think there's a bolt on the drivers side outboard of the carrier that is stopping me from removing this thing.
Does the radius arm have to be removed in order to remove this pinch bolt, or is there an easier way of doing this?
