foredeckguy
- February 10, 2010
- Snow Hill, MD
- '96 Explorer XLT
The dash brake light is supposed to come on for a few seconds when the key is first turned on to show the bulb is working and then go out to indicate the brake system is ok (fluid level for sure), all of this without the parking brake set. My bulb is good, the parking brake will turn it on, but I don't get the on/off cycle when first turning the key. Circuit diagrams in my manual and found on line do not include the master cylinder low level switch and whatever it is attached to. Anyone figure out what the 3 wires to switch should be seeing? Is there a control module for this?
This is the last item I failed inspection for and I only have 6 more days to fix it before the temporary tags expire! Thanks to all on the forum who have shared a wealth of information. I fixed the door ajar light, 2 inside door handles and latches, dash light and indicator bulbs, EGR fault, found keypad code, replaced shocks,rear bumper and upper control arms.
