papa1930
- September 4, 2012
- 1996 XLT 5.0 2wd
Hey all.
Just had some work done on my '96 XLT which included replacing odometer (think he just replaced whole section (from junkyard). Anyway, just picked it up yesterday. Everything (gauges) seemed to be working fine, but then it got dusk, and I turned my headlights on and they worked, but the dashboard light did not come on.
From what I can tell everything works fine except for 2 things. The dashboard light is not working, and the overhead light dimmer switch also doesn't work. I can turn the overhead light on from the overhead switch and it works, just not the dimmer switch on dash.
I pulled the fuse box, and checked no.7 fuse, and it looks ok, though I haven't used a multimeter yet. Am I checking the right one? It's a 7.5 amp fuse labeled "illum. switch" in the owners manual. Is there anything else that could make just those 2 things not work?
I want to check everything I can myself before I take it back.
Thanks in advance.
Thanks in advance.
