You can't just unplug the DRL module if you don't want running lights, your headlights won't work. I wanted to disable my running lights so I had to get a plug which completes the circuit. It is only like $10 from the dealer.
I had a similar problem...compounded with the fact that sometimes the headlights stayed on (autolamp never shut off). Turned out it was the GEM module that was the malfunction.
cheers
