do i need custom belt for iraggi overdrive pulley? | Ford Explorer Forums
1meanGTA
'98 Eddie Bauer
i've got an iraggi 240 amp amputator with the smaller overdrive pulley. measured it with my caliper and its a half inch smaller diameter than stock. says in the instructions to use a belt half the difference smaller, so i went to advance auto and asked for a belt 1/4 inch shorter than my stock belt, they tell me they only come in 1/2 inch increments.
so i get 1/2 inch shorter than stock, put it on, start the truck, smell something, smelled sort of electrical so i thought maybe it was just the new alternator, took my eyes off it for 2 seconds to check the voltage hear a loud ting and shut it off. my serpetine tensioner was pulled so tight, it was sitting at an angle, the bearing heated up enough the thing came right off. i have no idea where the bolt went.
i ran up to the junkyard and got 2 spare tensioners real quick. but what do i do about the belt? the stock one is going to be way too long right? i haven't tried it but i seriously doubt it'll work. do i have to get a custom belt made?
Did you try the stock belt? I can't believe a 1/4 inch made your tensioner break off! wow.
well believe it now mutha####a, we gotta get this truck back on the road!!
lol sorry watched pulp fiction yesterday...
it was a half inch shorter, the next smaller size advance auto had. going to try the stock belt now but i doubt itll work.
stock belt ended up working just fine, what a waste of time....
still having the voltage drop to 12.1 when i play young jeezey trap or die if im sitting parked and push it to the limit. im still using the stock battery though, and i only ended up doing the 1/0 gauge on the alternator ground and alt to battery + before i started it and burned up those bearings.
going to do the battery ground tomorrow, if that doesnt help i'm gonna have to figure out a way to stuff my 31 series yellow top in there. if THAT doesnt help i'm gonna have to buy a second one, which i dont really want to do.
when i did the alternator ground to chassis i just stuck it between the alternator and the mounting bolt, grinded the paint off of course. thats fine isnt it? my old f-body alt had a grounding post but this one doesnt.
i'm still having trouble finding the right sized belt for my smaller iraggi pulley. its exactly 1/2 inch smaller in diameter than the stock pulley. my belt is tight enough to keep the truck running with a horrible squeal, and after running for a few minutes it will walk up on the edge of the power steering pulley and the squealing stops, everything works ok, but its gonna tear that belt apart. i think the iraggi's pulley may actually stick out a bit further than stock also to make it walk up on the edge like that, but i dont think it'll be a problem if its tight.
instead of getting a custom belt made (they come in 1/2 inch increments and i need 1/4 inch shorter than stock) i was thinking i could just stick a few washers between the alternator and the mounts to raise it up a hair and remove that slack. will that work ok, or will it cause me horrible alternator whine or something?
Go to another parts store, autozone sucks and you can probably find something suitable somewhere else, as long as its close the tensioner should take up the slack.
i know better than to go to autozone. napa and advance auto both told me that. right now im using the stock belt and its ok but a little loose, squeals bad until i walks up on the power steering pulley. next size smaller destroyed my tensioner.
Washers will work but you will have to mess around with the amounts to get it right. Personaly I would use washers to determine the amount of lift I needed then use that measurement to cut some spacers out of tube.
You have some other problem.
The tensioner can deal with quite a bit of variability in belt size.
Twice in the last year i've had to change belt lengths (when i added my second alternator, and when i added my e.d.c.) and in both cases i was able to simply use a string, guess, get it close, and let the tensioner do the rest.
additionally, the pulley being 1/2" "smaller" doesnt mean that the belt should be the same... what matters is the circumference of the pulley.
It really sounds like you should be running a stock belt
I suppose it also sounds like you need a few deep cycles- at some point even if the alt can output more amperage (on average) than you are drawing (on average) you can still get into trouble unless you have some solid storage.
i am running a stock belt. i was planning on just having a second group 31 optima yellow top in the rear. you really think i need more than 2 with only 3kw?
need or want?
i ran two svr 80-12s when i had similar power requirements as you- worked decently well.
you'll be "ok" with one
