Door handles broken or electric locks not working & rear window wiper blade goes too far down | Ford Explorer Forums
rogueexplorer1
Phoenix, OR
1998 Explorer Eddie Bauer
I have several handles that aren't working properly;
drivers side rear door lock won't unlock & can't open the door. How do I get the door panel off to check what's happening in there without being able to open the door?
Passenger front door lock doesn't unlock to be able to open the door; have to use inside handle to open the door. Once it's unlocked I can open the door from the outside handle. Now the rear hinge on that outside handle is broken. Will replace.
Lift gate trunk handle doesn't spring back; have to push it down so the latch stays closed.
Rear window wiper goes down too far & won't come back up to wipe the window. Is this the relay that's bad?
Rear window washer doesn't work either. Does this washer get fed from the front washer reservoir? I don't see a rear one.
