Door Keypad | Ford Explorer Forums
Door Keypad
Hawkrider
Jacksonville, FL
'97 XLT
What is the easiest way to remove the keypad from the door for either replacement or repair? Thanks in advance.
Hawkrider
If I remember right on the explorers, if you open up the door and take off the trim on the inside of the door, there is a screw that holds it in. I might be thinking of the f-150's though, I know I've worked on both.
Is there a way to reset the code on the door keypad. I bought the truck used and did not get the code from the dealer because they did not get it. Non-ford dealer I bought it from.
Nevermind. I did some more reading and searching and found the code. This board is great for finding simple solutions.
