door won't lock | Ford Explorer Forums
door won't lock
JAMES209
fort worth,tx
2000 explorer 5.0L E B
1999 EX Drivers door won't lock.
I had the opposite problem with my 2000 driver door. It would lock, but not unlock. I took the door panel off, added lube in several places.
Worked the rods a few times, and it works ok now. I had a similar problem with the rear hatch. A little lube and worked the rods a few times, ok now.
If lube doesn't fix it tell us if it works with the key, the remote or from inside.
On my sisters truck it done the same thing, try looking for a bent rod. We changed the parts out from a parts truck and now it works fine
