Drivers' door red reflector Lens | Ford Explorer Forums
Biggles62
Bristol, United Kingdom
1999 UK Explorer Red/Grey
Has anyone got any ideas on where I might find a reflector lens for the drivers' door on my Ex. It is the type that is all red. I will also need the little thingumyjigs that you attach it with. Mine is missing and has no fixing points.
Thanks in hope
Mike
P.S. Sincere thanks to all for pointing me at Justin Woodham over in Wales. He did a fantastic job on the timing chains mods. She runs beautifully now. He also found a minor leak on the manifold that was causing it to miss a bit at idle. Brilliant job.
the little clips tend to brake when the reflector is removed from door card if you still have the reflector suggest sticking it back with clear silicon mastic. cheers chris
Thanks Chris, didn't know that. Will bear it in mind. I don't have the reflector. It must have fallen off in the dark and I didn't hear it.
