Robert
- October 26, 1999
- Location
- CA
- Kelseyville, CA
- '13 Ram 1500 Longhorn
I sent an e-mail to Edelbrock regarding my IAS shocks that I purchased three years ago. My Explorer has gotten very bouncy over most surfaces. I pulled my front shocks off and pushed them in by hand. I could easily push them in with little effort. Wanting to be sure, I decided to perform a more scientific diagnosis on them. I put them on the bathroom scale and pushed down on them. I found that it only took about 35 lbs. to push them in. Now I remember when I got them that I had a very difficult time pushing them in when they were new. I had to put one end on the ground and practically stand on the thing to get it to go down. Having had one of my Edelbrocks replaced under warranty a year or two ago due to a leak without too much difficulty, I decided to try out Eddelbrock's lifetime warranty again. I have posted it at the end for referrence. I sent an e-mail to Technical Support to get an RMA# to return my shocks so they could test them to see if they were still performing to standards (I knew they weren't). I told them that I had put 45K-50K miles on the shocks and they were very weak now. I guess I read too much into their lifetime warranty since I was not expecting the following reply:
"Hello :
Your shocks may just be worn out. In that case, there is no warranty on them; you just need to buy another set. The warranty covers any defect you may have with the shock / shocks.
Please look over the chart, and feel free to contact me if you encounter any defective shocks.
Thank you,
David
800-221-1666 x 2916"
I knew my shocks would not last forever. I had expected though that my warranty would last for as long as I had the shocks installed on my vehicle (kinda like the lifetime warranty on brakes, mufflers, etc.). Since my shocks wore out though (which apparently isn't a defect) they have no warranty. I also found it interesting to that one of the conditions of the warranty is that "Damage or defects resulting from . . . off-road use" would not be covered under warranty.
I was planning on taking my four new Edelbrock shocks (provided they sent them to me) and sell them for about half of retail. I also was planning on buying OME shocks but changed my mind when I found out they only have a 2 year warranty. I wanted my next set of shocks that I purchased to be the last set I had to pay for on my Explorer (as I had originally hoped for when I got my Edelbrocks).
I ended up getting a set of Monroe Reflex shocks that feel every bit as good as my Edlebrocks did when they weren't worn out. The benefit being that they were only $40 each rather than $75 each. They also have a lifetime warranty. I'm sure it is probably the equivalent to the Edelbrock lifetime warranty but regardless, if I can get an equivalent shock for a little more than half the price and have it last (hopefully) as just as long, I'm going with the cheaper of the two.
Edelbrock's Warranty:
"Edelbrock IAS® Strut & Shock Absorber Limited Lifetime Warranty
Edelbrock Corporation guarantees for a limited lifetime each new Edelbrock IAS Strut & Shock Absorber to be free from factory defects (except for finish and shock boot) from date of purchase, provided that the product is properly installed, subjected to normal use and service and that the product is not modified or changed in any way, negligence by customer or installer, or used for racing or competition purposes. Should a part become defective, it should be returned to the original selling dealer or shipped freight prepaid to Edelbrock Corporation. It must be accompanied with the sales receipt and a clear description of the problem. This warranty is void on shocks used in racing applications except for known, proven defects in material or workmanship.
Edelbrock Corporation reserves the right to replace or repair the defective part and return said part freight prepaid. This warranty covers the replacement or repair of the product only and does not cover the cost of removal and installation.
Damage or defects resulting from collision, improper installation, off-road use, road hazards or racing, are not covered by this warranty. The warranty for Edelbrock IAS Struts & Shock Absorbers extends only to the original purchaser only for the lifetime of the original vehicle in which it is installed. "
"Hello :
Thank you,
David
