fl51trac4me
- June 29, 2015
- 02 2wd trac
every piece of info iv'e read says you can cam up a mass air 5.0. yet you can't cam up a eec-v 5.0 even though it's a mass air engine. if a mass air pcm "learns" its parameters from the maf...what is the exact reason eec-v won't work with mild-wild cam?seems to me timing is perfect with mag trigger.what blows the eec-v's parameters? low overlap? educate me please...i need to know as i'm almost done building job 2 5.0 trac from 98 mass air exploder, and want to wake up sleeping intake/heads.
