boggs1227
- February 19, 2008
- Flowery Branch , Georgia, 1994 sport 2wd auto
- 2005 colorado 2wd 5spd
dpfe's of the metal caseing type are known to go bad ( even new out of the box) the new motorcraft part is now in a plastic case and also a new style connector is required .
motorcraft part # -----> 4W1Z9J460AA ( w/new connector)
.... the " 4 " at the start of the # is for the new connector kit...if you find this and the part number starts with a " 1" then the kit does not have the new connector .....also it's best to solder the connections instead of crimp connectors .
this is just for anyone with egr code problems ( like 327 , 332 , etc...) that when your engine is spitting out codes for such then 8 times out of ten the dpfe module is the culprit ( SO BUY THE CORRECT PART THE FIRST TIME, it will save you alot of headache if you don't ) .
tho it's better to have silicone hose's to hook it up with ( rubber will not with stand the temp's for very long and crack) ...i tried to locate silicone hose's but none of my parts store around me carried them .
