That is the vent, no way to determine its functionality by sight. Cleaning would be a first step, be careful, don't get fluid in the motor end. A little goes a long way. A bit of lube on the metal shaft is a good idea too.
Hey guys, so I cleaned the iac and it really wasn't all that dirty. But then I got to thinking, my temp gauge has been all over the place and sometimes doesn't move at all. If my temp sensor is bad, not only would it explain the jumpy gauge but also everything else. If the computer thinks it's a temp it's not that could really do some major tomfoolery with the entire system.
No, the gauge runs off a separate sensor. Again, use the scan tool to verify ECT from the PCM. If that don't follow the gauge, replace the single wire sensor along with thermostat. Beyond that, these engines have issues with cracked heads, causing gauges to move around along with misfires.
