rblais
- January 25, 2005
- Utica, NY
- 2000 Mountaineer
Hey All! Has anyone had this particular electric problem on their 2005 Mounty or Ex and was able to fix it without taking it to the dealer?
Out of the blue, but after wet weather, my truck developed a problem where the "Door Ajar" message lights up on the message center and at the same time the dome light comes on and the driver side door lock switch quits working. This happens now every time I open the driver side door. In the morning, I unlock the door, open it, get in and close the door and start the truck. The door ajar message comes up, dome light stays on and lock switch will not function. I get out of the truck and make sure all doors are closed, including lift gate and rear window. I get back in and drive away with dome light still on, door ajar message still showing and lock switch not working. After about 30 seconds, dome light goes out, message disappears and the lock switch works! I get to work, open the door and all the problems return with the dome light staying on and the lock switch not working. The light goes out on its own after about 10 minutes, I think because of the battery saver function.
I know this sounds rediculous and I apologize for the detailed blow by blow description but this is driving me nuts. I sprayed all the locking mechanisms with silicon lube, took the door panel off on the drivers side and disconnected all wires looking for corrosion or faulty grounds. Everything looked clean and dry. Checked all related fuses under the dash and under the hood and disconected the battery thinking maybe it would reset itself, but nothing worked.
So, has anyone experienced this nonsense? If so, please reply before I shoot myself in the head! Rant over, thanks.
