Electrical grimlin | Ford Explorer Forums
Electrical grimlin
CHuntMD
Upper Marlboro, MD
97 SOHC XLT, 94 4.0 SC
94 OHV w/120,000 miles
Got this weird electrical problem. Both left and right turn signals flash double time just like when a bulb is out. But when I apply the Brake with the turn signal on they return to normal speed.
When I apply the brake the radio display/clock goes out.
When the headlights are on everything is perfect! ;)
Could it be a bad/loose ground? ideas?
Thanks
Chris
Never seen that happen :confused:
Check grounds and look at the light bulb sockets. Make sure nothing is shorted in there and that you have the correct bulbs.
It was the trailer hitch connector. I cut it off and problem is solved.
