coghij1
- January 9, 2009
- Phoenix, AZ
- 2002 XLT 4WD V8 4.6
I've come to the conclusion that something is draining my battery while the vehicle is turned off. I've been getting surviving on my 2nd brand new battery by removing the negative battery cable every time I turn the car off. So far so good. But I NEED to FIX it!
I've tracked it down somewhat... With the vehicle turned off I removed the negative cable and stuck a tester light in series between the cable and battery terminal. The light turned on so I began pulling fuses to see which fuse series is running. Pulling the fuse in use should turn off the light, correct? So I get to fuse 20 inside the passenger compartment and the light goes out. Fuse 20 runs "PATS, Driver seat switch, Memory switch, Driver seat module, BSM, Sunload sensor." So now without that fuse (5 amp) in, my battery isnt being drained.
I just have no idea where to go from here... Any suggestions??? I dont know how to check the Passive-Anti-Theft-System. I dont even know what the BSM or Memory switch are!
