jcasey007
- March 17, 2009
- Stratford Upon Avon, Warwickshire
- Jeep Commander 5.7L HEMI
Hi All
After a 2 hour search on the forum for my answer, I've decided to post a question. Sorry if there is a really good post out there on this already, if there is, please point me in the right direction.
So on to the rear end now, I have a weeping rear axle seal so want to do both bearings and seals. I've noticed that the outside rear brake pads on both sides are worn more than the inners and that there is about 3-4mm of end float when I dont have the pads in. So how do you adjust the end float or is somthing else worn in the diff. Apart from the weepy oil seal on one side the diff is fine and quite
cheers as always
jim
cheers as always
jim
