engine idles rough when cold | Ford Explorer Forums
cnote76
St. Charles, Mo.
1991 XLT
Here is my quandry. I read the threads on the IAC, however I wanted an outside opinion on my situation. Every day when I start my 91 it will barely crank up then die, then when I restart it stays at idle, a little rough though. When it is at idle and until it is really warm it sounds like a semi-truck or a huge vaccuum. I also noticed my amp guage bouncing around like crazy until I eccelerate, then it steadys out. My fan is cracked in several places and I will be changing that out next week. Any ideas?
Sounds like your TPS could be giving you problems too:( How is your altenator?
Bad alternator, sounds like the regulator may be going, weak spark will cause it to run rough, it may be taking a few seconds to balance out and put out the right amps.
