Engine Problem | Ford Explorer Forums
Engine Problem
Big Blue
Winnipeg, MB
92 XLT
Check engine light came on, engine died, now won't start. Engine fires when turning over with starter, but won't run. Any ideas what can be wrong?
mine has done that a couple times.turned out to be a fuel pump relay.Don't know if that wrong with yours
Check AFS
I would disconnect the air flow senor and try to start it if it stays started drive it around the block if it runs good around the block you need a new Air Flow Sensor. Thats what mine needed
I would probably pull codes before doing anything else. See if that gives you any clues.
