asp84
- July 2, 2001
- Tempe, Arizona
- 1998 V8 AWD Mounty
Think about this way.... If your going through all the work to adapt a fullsize tranny, and an engine that was not made for your Explorer, why not just go with a 5.0? None of the engines you are talking about, are popular Explorer conversion engines. ....and would require extensive production of new custom parts. The 5.0 conversion has many companies backing it up.....and Ford even thought it was a good idea too, so they started putting them in Explorers in 1996! The only thing that would be a direct fit and require no modification and custom parts would be a 2.9L V6 from a Pre-1990 Ford Ranger!! (for the engine swap) If you just want to keep it simple, build up your 4.0 and get a Mazda 5spd. Or if you have $5-7K to spend go with the 5.0 H.O. With Automatic Overdrive tranny.
Sorry to bother you... I am just venting my troubles with the A4LD and 4.0 setup. and trying to justify my 5.0 Conversion!
Do as you wish....and good LUCK
